Help identify cpu capacitor on my laptop
Hi,
This is an Acer Aspire 4738 laptop with cpu area overheated creating intermittent os hangup. I had changed a new cpu fan and apply new thermal paste but the hangup is still there.
At the back part of the triangle cpu area, there are 3 smd tantalum capacitor with marking of 330 on first row and 08D1Y on second row. Not too sure what voltage rating are those caps but i suspect 330uf. I tested them by desoldering one leg off and esr reading is about 17Ω… which is way too high. Does anyone know what could be the voltage rating like is it 2.5v or 6.3v?….
I have been searching for schematic or parts list but unable to find. I think i need to buy replacement cap for those 330 but unsure of the voltage rating. Please help. Thank you.
4 Comments
@mikey5791 the 3 digit capacitor code 330 stands for 33 pF. As for the voltage you can’t go wrong with the 6.3v on a cap since its capacitance is the importance not the voltage.
The only other way to find out would be by getting a schematic for your board. It may or may not be available so that would be a bit of a crapshoot
by oldturkey03
Hi oldturkey03,
Thanks for reply.
When i measured the capacitance on those 330 caps, they are more or less in the range of 325 to 360uF. Thats why i m a bit confused since you mentioned they are 33pF type. Are those caps getting bad slowly now ?
Schematic is not available from any source at all. Cheers.
by Michael Chu
@mikey5791 ,
Are you sure that the marking on the capacitor is 330?
Using this calculator @oldturkey03 is correct in that 330 = 33pF.
325uF = 327 and 360uF = 367
by jayeff
@jayeff
Hi,
Yes, definitely the marking is 330 on those caps.
by Michael Chu
