PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
How to remove stripped screw
Um so On my controller I was able to open all the screws except for the bottom left which I pretty sure is stripped. Can someone help?
1 Comment:
A screw on a WowWee MiPosaur looked the same as that, though an identical part (and almost every other part) used Phillips screws, so likely it was a Phillips screw that would need something like a Hex screwdriver to get it out.
by
Add a comment
1 Answer
It's not stripped the head is rounded out. It looks like it takes a allen wrench. Try wrapping the head of the allen wrench with cellophane/plastic wrap to help fill up the area around the wrench head and try it. Or you can try the metric size or standard size which is whichever is not the regular size wrench. The slight difference in size can make it grab better. The last choice is to drill it out
Add a comment
Add your answer
Ezy Cuttychiken will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 3,063
