Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
How to fix this boot?
Hi,
My iPhone has no previous backup and while it was on charge yesterday(the battery was flat), the Samsung adopter exploded. Its charging port was now not working. I tried to put the motherboard into another phone and it nows displays the screen but the apple sign stays on like for a minute and it restarts again to show the same thing again.
Is there any way i can fix that without loosing my data?
Thanks a lot..
Score 1
Add a comment
Chosen Solution
This sounds like you have damaged one of your charging IC’s when the charger failed. This is quite common and can easily be repaired by any reputable phone repairer that offers microsoldering.
Score 1
2 Comments:
when i changed the housing of the phone, the motherboard works in the other housing..This means that the charging IC seems to be fine..and on connecting to the cable, it opens but doesn't boot up and connect to iTunes.
If you could help please?
by
@Sidick angel So it boots in the other housing and everything works?
by
Add a comment
You can send it to iPad rehab ipadrehab.com they can retrieve data. It costs 300 dollars only if they get the data.
Add a comment
Solution for boot loop in IP7: https://www.youtube.com/watch?v=bQMaqHXG...
Add a comment
Add your answer
Sidick angel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 165
