Samsung TV has no picture but there is sound
Hello,
I’ve followed some suggestions I’ve seen here but I still can’t get the picture to show on my Samsung un55es6500 model tv. The sound is perfect. I did the flashlight test and didn’t see any pictures so I replaced the t-con board. Issue still remains. When I disconnected the main board from the power supply I can see the led backlights on. So I replaced the main board. Still no progress and I’m looking for ideas. Before I replaced the main board I measured the voltages on the 2 connectors to the led panel. Here is what I got:
CNL802A
L1 to L4+ 77.9V
L1 to L4- 31V
CN802B
R1+ , R3+ 124.3V
R2+ 124.6V
R4+ 125V
R1 to R4- 77.9V
disconnecting the panel connections the voltages on CNL802B jump from 124V to 299V which I assumed it meant the power supply unit is working fine.
any help what to check next is appreciated.
thanks
2 Comments
Thanks for your response @jayeff
Sorry, that was a typo. I replaced both the t-con and the main board.
by motukile
@jayeff
Hello. Sorry it took this long to get back to this. I added new image to the question. Looks like the left panel is not working, when I disconnect the tcon ribbon to the left panel, there is image showing on the right panel. Nothing is showing on the left panel. I cleaned the connections on the ribbons and got the same results. Does this mean the panel is damaged and can't be fixed?
by motukile
