Can the HP Touchpad LCD glass screen be removed from the frame?
Can the HP Touchpad LCD glass screen be removed from the frame and replaced with the iPad front glass?
Menu
Your Settings
Cancel
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
Rep: 1
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our StoreRep: 1
Yes it can!
Comments:
How? Not that I do not believe you, but it will help your answer if you let us know.
by oldturkey03
Rep: 1
use a butter knife to pry it loose along the edges. It snaps back into place when finished.
A hair dryer or heat gun helps when trying to remove the old glass and tape.
You can also bake the front panel assembly in an oven; 175 F seems to work OK. But then there are more places to burn yourself when it comes out...
In either case, you want to have the front panel detached so that you aren't cooking sensitive electronic components.
I don't know the iPad front glass, but it probably with the HP TouchPad, which has its own digitizer -- I doubt they're pin-for-pin compatible.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,243
