My Onn tablet, powered by android, is stuck in the safe mode
My tablet is stuck in safe mode, and I've done all the regular stuff too get it out. I went to my boot menu and it's written in Chinese!
HELP!!!
HELP!!!
Hold power button and vol down button at same time till it comes on then let off of power button while still holding vol down button. It will take it to safe mode then power tablet off. Then hold power button and vol down button for two seconds that will take u to boot loader options. It may show them in Chinese if so use vol down button to scroll to the last option then push vol up to select it. Then it will power back on and problem should be fixed for the unresponsive screen issue.
You’re awesome- thx
Thank you!! You're a lifesaver!!
I scrolled down to the last option and pressed up, but it's not doing anything. I've tried a few times. What do I do?? Please help!
Nevermind, I powered it off and back on manually, and I believe it's fixed now!! Just has to charge a bit more. Thank you so much!!
It won't work I'm trying its not working
I know how to fixs it easy just hold the power button intell it shows the button power off hold it for 5 secs ok good luck
Itell it shows ten off safe mode ok
Turn off safe mode
Thank u so much! It worked!
Just got a surf onn 7in how long does it need to charge up & it showing boot mode don’t know if it’s charging or not
thanks so much that done the trick. Really simple fux.
On the front of my table it has FastBoot mode on it and it won't let me do anything I can't remove it what do I need to do
So my android 7” tablet onn and its stuck in safe mode I get it to the Chinese options go all the way down then trying to press the up volume to select it it won't select it what do I do ? Plz help its my 8 year old daughters birthday tablet
Scroll all the way down using volume then just tap the last option...that worked for me on the 10 in.. It will (should) reboot and be good to go..
I purchase a Wal-Mart omni tablet from a friend an age for hot the password. I reboot it internet is on. After that I try to enter a e-mail address and password also a code .I always get the same something went wrong or try again. It gave me the same answere. What can I do? Thanks Bar
I really need help I'm getting so !#^&@@ right now okay I was transferring stuff to this tablet from my phone and it keeps showing this unlock thing and the background Is fully black I've tried powered it down showed the same thing then I tried to restart it and still doing the same thing the I tried to lock down it same thing AGAIN!. The I tried to reboot to safe mode and same thing keeps happening
Past 24 Hours: 12
Past 7 Days: 57
Past 30 Days: 297
All Time: 33,689
16 Comments
I bought my grandson a onn tablet and some how he got the screen where it's not working I reset the tablet from start reat the whole thing it saids vision setting at the bottom but I cant tap the screen to fix it
by stacyannette8495
i reset it and its all in chanise
by DELANNY GAMBOA GUITY
I have a 7'“ Onn Android tablet! I pressed the power button to get screen on an when I did the screen was blue, I powered it off an tried turn it back on but it wont do anything an it has charge to it! Can anyone tell me what to do to fix it?
by Tina Blackburn
I have an ONN surf 8” tablet with the screen not responding, it’s only got a sim lite on the screen. Have any ideas and can I repair it myself?
by Ruchard
I got 2 of the 10" tablets & used the 1st 1 mb a month, overheats & shuts down all the time, the 2nd 1 I've been using for 2wks & is now doing the same thing as the 1st 1 overheating & shutting down, I've tried to let them recharge but takes all night to just get it to 50%, I'm very frustrated, what can I do??
by Naomi Kandel
Show 11 more comments
