Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
audio ic positioning matter?
When removing an audio integrated circut do you need to pay attention how it came out so it can be re-installed the same or can you spin it around like the wheel of fortune then re-install? Thanks in advance obviously I am a newbie.
Add a comment
1 Answer
Chosen Solution
You need to install them with A1 on the chip which is usually marked with a dot to the A1 pad on the logic board. If you put the chip in another orientation you will have voltages going to where they shouldn’t, essentially causing other chips to fail and if a high voltage ends up going to the CPU its game over.
Score 1
2 Comments:
I cant see it
by
It is hard to see if you don’t have it at the right angle as it is shiny.
by
Add a comment
Add your answer
mikespring1972 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 116
