13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Why does the MacBook Pro doesn't boot up? (after top case replacement)
Hi!
I have installed a new topcase on my Macbook Pro (a1278) mid 2012.
Before installing it, the computer worked fine without a keyboard (I would usually remove the battery and power it on with the magsafe cable, since the keyboard wasn’t working).
Then I replaced the topcase (with Keyboard, no trackpad) and now the computer doesn’t turn on.
I tried powering it on with the magsafe and even with the Logicboard’s power pads and nothing.
I have attached a picture in case anyone has any suggestions?
Thank you!
Add a comment
Chosen Solution
This has been fixed after I put the rear/bottom case back on the MBP.
I assume I had a cable poorly connected and it seems that puttng everything together solved it!
Add a comment
Most Helpful Answer
Your photo shows the battery is not plugged in.
Score 1
1 Comment:
Yes I know :) I was turning the computer on with the magsafe only
by
Add a comment
Add your answer
Manuel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 62
