2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Questions View all
Not able to left click. Firmware issue?
I have a Late 2013 15” MacBook Pro that won’t left click. Right clicking works just fine. Note that the physical clicking movement works fineThis happened randomly about a year ago. After getting a $500 estimate from several different places to replace the top case, I put it in a cupboard and got a new MacBook.
Fast forward to today… I’m bored. I picked up a new top case on eBay and installed it myself. But now, the issue persists.
The weird throng about this is I can’t left click with anything. External USB mouse, external Bluetooth mouse, nothing.
Ive noticed that it I can left click with an external mouse in the boot menu but only sometimes with the internal trackpad.
The other weird thing is if I disconnect the trackpad cable from the logic board, I can use an external mouse with no issues.
I suppose its possible both top cases have the same issue but I find that unlikely.
Here are the things I’ve tried:
Resetting SMC
Installing a new SSD
Re-installing MacOS
Installing all available updates
Can this be a firmware issue? If so, how can I fixit it?
Thanks in advance!
Add a comment
1 Answer
I think your real issue is a messed up Trackpad cable I would have replaced that alone 15” Macbook Pro retina Trackpad Cable, Apple P/N 821-1904 or the full Trackpad MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad
This is not a logic board firmware issue.
MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad Image
Product
$69.99
2 Comments:
So you think both top cases have the same issue?
by
The uppercase typically doesn't come with the Battery, Trackpad cable or the Trackpad its self as a proper Apple part. As an example 15" MacBook Pro retina Top Case & Keyboard
If your's came with a trackpad I would swap out your original trackpad over. to see what it does then. There is firmware within the chip thats on the trackpad cable which maybe your issue.
by
Add a comment
Add your answer
Austin Martin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 45
