Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Electric discharge near USB port, won't turn on anymore
On my MacBook Pro from 2013, there was a electric discharge (visible from outside) near the USB port on the left side (below the power connector) and the computer immediately turned off. It is still possible to smell burned electronics on the USB port.
Now it won’t turn on again (no display, fan not turning.) I tried turning it on with the power connector connected or disconnected. I and opened it up and disconnected the battery, but it still won’t turn on.
Is there anything that can be done to repair it, or make it work long enough to copy files off it?
Add a comment
1 Answer
Just order replacement for IO ports.
MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement
If you have had encrypted SSD, you cannot get data unless you have similar macbook pro.
MacBook Pro 13" Retina Display Late 2013 SSD Replacement
MacBook Pro 13" Retina Display Late 2013 SSD Image
Guide
Difficulty:
Moderate
10 - 45 minutes
MacBook Pro 13" Retina Display Late 2013 I/O Board Image
Guide
Difficulty:
Moderate
2 Comments:
The damage was on the opposite side (where the magsafe connector is) , and these ports seem to be part of the main board.
Could removing the IO board or any other part (damaged connector etc) possibly make it boot so that files can be copied off it?
by
I was wrong then... Remove the board that showed the electric discharge. Unfortunately, I think u will need every part to boot machine and copy files.
by
Add a comment
Add your answer
timlenertz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 44
