LG de2 code after drain pump replacement
LG washer had an OE code, I replaced the drain pump and put it back together, now I have a de2 code. I replaced the door lock switch, but to no avail. It clicks when I starts the cycle then displays the de2 code. What else can cause this besides the lock switch? Also, I noticed that the error goes away IF I unplug the newly installed drain pump, but the machine still doesn't start filling with water.
@jayeff it's a clothes washer, model is cm3050cw
by Samuel Blackwell
@sammob88 ,
I cannot find how to enter the diagnostic mode for your machine but did you try a power reset after the replacements to reset the machine?
Unplug the machine from the wall outlet and then press and hold the Start/Pause button for 10 seconds and then release.
Reconnect the power cord to the wall outlet and then try to start the machine.
Apologies if you have done this already.
by jayeff
I apologize its WM3050CW
by Samuel Blackwell
