Protocol Wi-Fi drone with HD camera, VR headset and GPS. Model number 6182-7XB, comes in black or white.
Why won't my drone lift off. 3 sides lift, but the right backpropeller
Is there something I can do to make my drone drone propeller spin at the same speed as the others
Add a comment
It is most likely the same issue I am having. The pin inside the propeller gear broke. You'll have to replace the pin in the gears
Add a comment
My kids flew my Kaptur Protocol drone into a lavender bush and one propeller stopped working, although it tried to spin, just very slowly.
I took it apart and discovered that the pin holding the main gear had popped, and after pushing down hard on the gear while supporting the bottom of the motor casing, managed to pop it back in. I wish I hadn't had to take apart the entire drone to figure that out, but it works now, thanks to an iFixit contributor!
Add a comment
Where can I find a propeller shaft/pin to replace a worn/ broken one?
Add a comment
Add your answer
madisonearlharper228 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 281
