Replacement display (Replace A1989 -> A1706)
I am using A1989. Is it possible to replace it with a 1708 display?
Is it impossible because I have a T2 chip?
I want to use a new A1706 display
What you want and what works are very different!
No! You can’t use the older display used in either the two or four port 2016/17 models in the newer system. They are not compatible!
Here is the correct part for your system:
Presently there is no used displays available which would be cheaper.
how about A1707 2 port with A1706 4 port?
The A1706 system is a 13" and the A1707 is a 15" very different sizes!
And BTW both are four port systems.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 785
