Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
iPhone does not turn on after dock connector replacement! HELP!
Hey guys,
i just replaced the dock connector on my brothers 16GB 3gs. it didn't work for the last 3 months. i think i did everything alright, but it just doesn't turn on.
do i have to wait some time till turning on the iphone???
help me please.
thx
dom
2 Comments:
Before you replace anything else. Use a multimeter and see if you have power at the battery when you plug your cable into the dock connector. Always double check your work and make sure you do not have any crossed contacts etc.
by
If the IPhone is not charging or connecting to itunes, even after replasing the dock connector, it might be an shortcut. i had one on mine, because i cleaned my device while it was still turned on. in that case, the problem is not the dock connector, but the logic board. i`m not quite shure how you can repair this problem yourself, i just submitted then and gave my iphone to a repair shop. 52 euros and everythings working fine again.
by
Add a comment
1 Answer
Is the battery ok? Try to replace the battery. I include part below.
iPhone 3GS Replacement Battery
Please note that if replacing the battery does not help, it may be the logic board.
iPhone 3GS Battery Image
Product
iPhone 3GS Battery
$14.99
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,247
