Where is the t con board
The tv I actully have is the UN65RU7100FXZA, white screen with sound replaced panel, main board, and power board, no change……where is the t con board located?
Built into the main Pcb board. No separate. You can tell if there's two lvds cables going from the main board to the panel directly that indicates that the t-con function is built into the main PCB board
Hi @rbutch
If your TV has a T-CONN board it will connect the panel cables and main input board together towards the bottom of the unit. A small board usually only a few inches in each direction.
Wood and inverted/upside down picture mean that my t-con board is bad
sounds like cables are reversed. A bad T-Con board will likely produce bad to no picture.
@kimnelms no it does not. First you need to check your TV’s settings. Depending on make and model it may have that option in its settings. If all that is correct, then the issue is on your mainboard. Do not reverse the ribbon cables going to your TV panel. Those are not mirrored connections. By reversing the cables/connection you can shorten out the driver boards on the panel
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 44
All Time: 501
