A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
2017 MacBook Pro flashing lines on screen
The screen on my 2017 MacBook Pro suddenly has vertical and flashing lines almost like its suffering from some sort of interference. I’ve tried everything to fix it and I’m just trying to get an idea of what might be wrong. It does go away depending on what angle I have the screen at.
Update (04/04/2020)
Here’s a picture of what my screen looks like
1 Comment
Can you post a few pics or vid so we can see what you are facing Adding images to an existing question
by
Add a comment
1 Answer
Chosen Solution
Ouch!
I had feared that was what you where facing. The T-CON board has failed. This is located between the heat sink heat transfer radiators (in the Fn model it only has one). If you block the side & rear vents, have a lot of dust buildup or run your system hard you can cook it.
If you are lucky your system may still ben under warranty! EU has two years, If not, did you get the AppleCare+ maintenance contract? Otherwise you’ll need to do it your self, While not overly hard you do need to be careful with the ribbon cables.
Sadly, the T-CON is part of the display assembly and you’ll need to replace the assembly:
2 Comments:
Thank you for your help, I was really hoping that this was just a software problem. I’ll take it to an Apple repair shop on Monday and see if they can cut me a deal on a new display or a new laptop.
by
Apple Stores are closed! Some authorized service centers are open, so you will want to call first.
by
Add a comment
Add your answer
John Hawkins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 87
