System is not charging!
Hi @danj !
I am having the same problem as Kenny, my MacBook Pro is not charging anymore through USB-C. I tried all 4 ports, no luck.
I had been using a USB-hub for a while before it broke, does that make it more likely that some particular part on the logic-board has broken down? I only used the original Apple charger though.
The strange thing is, if I plug it in now, for a brief moment the laptop says its charging but then immediately stops charging.
Hope to hear from you!
Best,
Bram
