2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
MacBook Pro won't turn on after battery drain, magsafe give no lights
My MBP went off yesterday since I forgot to charge it up. I remember that the battery percentage was only 4 or 5 % before it shut down by itself. after the mbp was shut down, I press the power button immediately and the mbp was still be able to turn on and I saw the battery was only 4% and then turning off again. when I tried to plug the magsafe in, the magsafe adapter shows green light and I disconnect the magsafe. and trying to connect it again but no lights at all. Btw the charger is not the original one but it works fine all this time. can you help me to diagnose the problem? thank you
1 Comment
@rany with all of my respect, can I have your help
by
Add a comment
1 Answer
Chosen Solution
Well you got the double whammy! First it does sound like your 3rd party charger has damaged your system. This sadly is a common issue with these cloned MagSafe units What does a knockoff charger do to a Macbook Pro Retina? Why should you not use one?
You also appear to have a bad battery as well. But you’ll need to get your logic board fixed first.
5 Comments:
the battery is brand new and it was fine, just 7 cycle count @danj
by
Gee, I wish you had stated that in your question!
So... I would see if the original battery still has some charge, plugging it in did that work?
Do you have access to a real Apple charger?
by
yaa sorry @danj forgot to tell about the battery. The original one has more than 1300 cc. and actually I replace the battery a week ago because the battery is dead already. Do you think if I borrow the original magsafe would help?
by
I would give that a try!
Review this T/N Apple Portables: Troubleshooting MagSafe adapters
by
thank you very much @danj. I'll accept this solution first and will give the update here once I get the original charger
by
Add a comment
Add your answer
omisroadrianto will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 159
