Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
iPhone 6+ is dead and won't charge, but it says it is
In the morning I woke up, and my phone was dead. So I shrugged and left it to charge while I was at school. I came back after around 7 hours, and it still had no charge, but it said it was charging. So I moved it to another outlet, and still nothing. I tried another charger, nothing. Then I tried to plug the charger into my computer. Still nothing! I tried ANOTHER charger in ANOTHER port, and it still won’t charge. I tried taking off the case, blowing into the charging port. Nothing. So I’ve turned to the internet. My iPhone has always had a bad battery. It would drain very quickly, and when it says 30%, or something pretty low, it would just die. But I always keep it plugged in, so it’s fine. But I’m so confused, so, please help!
Add a comment
Chosen Solution
Your battery is faulty. The battery also sends data information to the phone besides voltage. Buy a new battery and your phone should be fine they are not that expensive.
You can use this guide.
Score 2
1 Comment:
Thank you! I will try this!
by
Add a comment
Have you try a hard reset by pressing and holding both the “Power” button and the “Home” button at the same time, till you see the Apple log?
Add a comment
Add your answer
Sunnycriicket will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 161
