Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Changed Display, now iPhone doesn´t turn on anymore.
Hey, I just replaced the hole Front Unit, exept the LCD by a new one(so the touchscreen and the middle-thing with home-button etc)
And now, nothing happens and it won´t turn on anymore, no matter how often I try to put it on.
Checked all the connectors a dozen of times!
Greets, Philipp
4 Comments:
With my old Front panel I can start now, but only white screen -_-
by
lots of problems with the no3 earpiece flex being not accepted by iphone. try leaving that off and see if it works.
by
------>Old Display, old LCD: White Screen, even without #3.But Working(Vibrate and ringing) Turning on only by HOME+ON-Button
------>New Display, old LCD: Nothing
by
New Display has now Wwhite screen too.
How to get my picture back.
And how can I power off the Iphone?
by
Add a comment
Iphone 3g/s dosent like changing parts while powered on
Reattach the battery and see if that works
Might be too late
3 Comments:
changing the LCD helped :-)
by
so problem was old LCD was damaged?
by
I think so, it is the only possible reason :-)
by
Add a comment
I had the same problem...but successfully live up my iphone.
Here are what I did:
- recheck connectors number 1, 2, 3 (make sure they are not broken or detached from their ribbon cable)
- recheck the connections to main board (perfectly fit)
- connect my iphone to iTunes, resetting the system to factory setting (iTunes will ask and do backup of all your data)
- if your iphone display iTunes symbol or any text other than white/black screen, then everything will be okay.
- after resetting, I restore the system firmware and data back to latest condition. some apps needs to be re-installed from appstore.
Hope you can live up your iphone again...
Add a comment
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 6
All Time: 788
