Monitor is turning off while Playing games, while I can hear sounds
I was playing games. all of in a sudden My PC monitor turned off, while I’m hearing sounds. It required a reboot of the PC to make it working. The CPU is still running and the Input signal is lost.
Hi,
What is the make and model number of the PC?
What OS is installed?
Try starting the PC in safe mode to check if the display works.
Search online for "(insert OS) safe mode," e.g. Win 7 safe mode or Win 10 safe mode etc to find out how to do this
If it works in safe mode you may have a video driver problem.
If it doesn't you may have a GPU or motherboard problem.
Does the PC have a plug in graphics adapter card inserted into the motherboard or are you using the onboard graphics supplied by the motherboard?
by jayeff
I have a Intel Core i5 7400, with Geforce GTX 750Ti and the graphics drivers are updated regularly
by Vamshi Krishna
@Vamshi Krishna ,
What is the make and model number of the computer?
Telling me the cpu and the gpu doesn't help much without knowing what motherboard they are connected to.
If it is a custom built computer the the make and model number of thhe motherboard will definitely help.
If a "brand" name computer then the make and model number.
Did you try starting is safe mode, you didn't say?
You also didn't say what OS is installed.
Help us to help you by giving the information requested otherwise the answers will only be general in nature and not specific to your particular computer and problem
by jayeff
Make sure the GPU is all the way plugged into the power supply. Also, check on it while it goes out. Is the fan on when there's no video signal? If not, the card could be broken.
by Void Frost
