The fourth-generation Surface Pro tablet, released October 26th, 2015.
Problem with new battery
Hello,
I put a new battery in a SP4. While plugged in, the SP4 will turn on, boot, run fine. It shows 16% battery, never more, never less. If I unplug from charger, the surface turns off instantly and does not turn back on until plugged back in. Can someone guide me in what to do here?
Add a comment
1 Answer
@focusedtech either a bad battery or issues with your charging circuitry. Replace the battery with your old one and see if that behavior is now different. If it is identical it’s your circuitry , if it has changed replace the battery once more with a different one. Of course always double check your work for properly seated cables, connections etc.
Add a comment
Add your answer
Brian Kosarko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 117
