iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
iMac only loads halfway on boot.
Hey, my iMac only loads halfway when I boot it.
It is running High Sierra.
It boots in safe mode, single-user mode, and recovery mode.
The hard drive checks out fine.
I tried resetting the SMC, NVRAM, and PRAM.
Any ideas?
UPDATE:
Here is the system.log
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class SUReachabilityMonitor is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate (0x7fff8d907168) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db3c0). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class SUPrinterScan is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate (0x7fff8d907d70) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db488). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class SUSharedPrefs is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate (0x7fff8d907230) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db4b0). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class SUPublicKey is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate (0x7fff8d907c80) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db528). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class SUSignedFlatPkg is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate (0x7fff8d907c30) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db578). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class SUPowerAssertionManager is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate (0x7fff8d907078) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db5a0). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class SUPowerSourceMonitor is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate (0x7fff8d9070a0) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db5f0). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class SUURLConnection is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate (0x7fff8d9072f8) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db640). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac suhelperd[348]: objc[348]: Class KeychainMasterHandler is implemented in both /usr/lib/libIASAuthReboot.dylib (0x7fff8e2aa138) and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd (0x10d0db6e0). One of the two will be used. Which one is undefined.
Feb 25 11:06:48 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:06:50 --- last message repeated 2 times ---
Feb 25 11:06:49 Seths-iMac Spotlight[350]: objc[350]: Class SPWebHistoryResult is implemented in both /System/Library/PrivateFrameworks/Spotlight.framework/Versions/A/Spotlight (0x7fff8d971308) and /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight (0x1084aaac8). One of the two will be used. Which one is undefined.
Feb 25 11:06:49 Seths-iMac Spotlight[350]: objc[350]: Class SPWebHistoryQuery is implemented in both /System/Library/PrivateFrameworks/Spotlight.framework/Versions/A/Spotlight (0x7fff8d9712e0) and /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight (0x1084aab18). One of the two will be used. Which one is undefined.
Feb 25 11:06:49 Seths-iMac Spotlight[350]: objc[350]: Class SPDefaults is implemented in both /System/Library/PrivateFrameworks/Spotlight.framework/Versions/A/Spotlight (0x7fff8d970f98) and /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight (0x1084aae60). One of the two will be used. Which one is undefined.
Feb 25 11:06:49 Seths-iMac Spotlight[350]: objc[350]: Class SPShortcutPattern is implemented in both /System/Library/PrivateFrameworks/Spotlight.framework/Versions/A/Spotlight (0x7fff8d971b28) and /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight (0x1084ab130). One of the two will be used. Which one is undefined.
Feb 25 11:06:49 Seths-iMac Spotlight[350]: objc[350]: Class SPAppDefaults is implemented in both /System/Library/PrivateFrameworks/Spotlight.framework/Versions/A/Spotlight (0x7fff8d970ea8) and /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight (0x1084ab3b0). One of the two will be used. Which one is undefined.
Feb 25 11:06:51 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:06:52 Seths-iMac com.apple.xpc.launchd[1] (com.apple.MRT.YaraScanService[313]): Service exited due to signal: Killed: 9 sent by YaraScanService[313]
Feb 25 11:06:54 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:06:54 Seths-iMac com.apple.xpc.launchd[1] (com.apple.CoreLocationAgent[356]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.CoreLocation.agent
Feb 25 11:06:55 Seths-iMac Dock[279]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] add: "No such file or directory" - 0x2
Feb 25 11:06:55 Seths-iMac pbs[363]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:06:55 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:06:56 Seths-iMac com.apple.xpc.launchd[1] (com.apple.quicklook[338]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Feb 25 11:06:56 Seths-iMac SystemUIServer[282]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
Feb 25 11:06:58 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:06:59 --- last message repeated 1 time ---
Feb 25 11:06:59 Seths-iMac CalendarAgent[268]: BUG in libdispatch client: dispatch_mig_server: mach_msg() failed (ipc/send) msg too small - 0x10000008
Feb 25 11:07:02 Seths-iMac nsurlsessiond[303]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
Feb 25 11:07:03 Seths-iMac Finder[286]: objc[286]: Class FIFinderSyncExtensionHost is implemented in both /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder (0x10e1e6dd8) and /System/Library/PrivateFrameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride (0x11435dcd8). One of the two will be used. Which one is undefined.
Feb 25 11:07:04 Seths-iMac xpcproxy[378]: libcoreservices: _dirhelper_userdir: 529: bootstrap_look_up returned (ipc/send) invalid destination port
Feb 25 11:07:04 Seths-iMac quicklookd[338]: BUG in libdispatch: 17G66 - 288 - 0xf
Feb 25 11:07:06 Seths-iMac Dock[279]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:07:08 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:07:11 --- last message repeated 2 times ---
Feb 25 11:07:11 Seths-iMac loginwindow[106]: There are still active callers
Feb 25 11:07:12 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:07:26 --- last message repeated 4 times ---
Feb 25 11:07:26 Seths-iMac loginwindow[106]: There are still active callers
Feb 25 11:07:29 Seths-iMac systemstats[66]: assertion failed: 17G66: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
Feb 25 11:07:45 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:08:19 --- last message repeated 1 time ---
Feb 25 11:08:28 Seths-iMac diagnosticd[420]: no EOS device present
Feb 25 11:08:28 Seths-iMac diagnosticd[420]: System mode client started - Console (419) - mode: 0xb
Feb 25 11:08:39 Seths-iMac Console[419]: BUG in libdispatch client: kevent[vnode] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:08:51 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:11:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.quicklook[422]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Feb 25 11:15:31 Seths-iMac syslogd[57]: ASL Sender Statistics
Feb 25 11:15:31 Seths-iMac com.apple.xpc.launchd[1] (com.apple.quicklook[423]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Feb 25 11:18:17 Seths-iMac diagnosticd[420]: System mode client stopped - Console (419) - clearing mode: 0xa, still active: 0x0
Feb 25 11:18:17 Seths-iMac systemstats[66]: assertion failed: 17G66: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
Feb 25 11:18:17 Seths-iMac backgroundtaskmanagementagent[426]: objc[426]: Class BTMLoginItem is implemented in both /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement (0x7fff8a443558) and /System/Library/CoreServices/backgroundtaskmanagementagent (0x1027ae860). One of the two will be used. Which one is undefined.
Feb 25 11:18:17 Seths-iMac backgroundtaskmanagementagent[426]: objc[426]: Class BTMBackgroundItem is implemented in both /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement (0x7fff8a4434e0) and /System/Library/CoreServices/backgroundtaskmanagementagent (0x1027aea40). One of the two will be used. Which one is undefined.
Feb 25 11:18:20 Seths-iMac Finder[286]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100006.Aqua): Caller not allowed to perform action: loginwindow.106, action = service removal, code = 150: Operation not permitted while System Integrity Protection is engaged, uid = 0, euid = 501, gid = 20, egid = 20, asid = 100006
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.AirPlayUIAgent[271]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.SystemUIServer.agent[282]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.noticeboard.agent[275]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.talagent[252]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.lateragent[386]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.cloudphotosd[327]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.CoreLocationAgent[356]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.wifi.WiFiAgent[322]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.universalaccessd[250]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent[379]): Service exited due to signal: Killed: 9 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.WiFiProxy[366]): Service exited due to signal: Killed: 9 sent by WiFiProxy[366]
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imklaunchagent[263]): Service exited due to signal: Terminated: 15 sent by loginwindow[106]
Feb 25 11:18:20 Seths-iMac sessionlogoutd[430]: DEAD_PROCESS: 106 console
Feb 25 11:18:20 Seths-iMac systemstats[66]: assertion failed: 17G66: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
Feb 25 11:18:20 Seths-iMac WindowServer[139]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:18:20 Seths-iMac VDCAssistant[183]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:18:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.coreservices.useractivityd[365]): Service exited due to signal: Killed: 9 sent by useractivityd[365]
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.rapportd[319]): Service exited due to signal: Killed: 9 sent by rapportd[319]
Feb 25 11:18:21 Seths-iMac systemstats[66]: assertion failed: 17G66: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
Feb 25 11:18:21 --- last message repeated 94 times ---
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.432.4294967295): com.apple.AssistiveControl (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.coreservices.useractivityd): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.coreservices.UASharedPasteboardProgressUI): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.432.4294967295): com.apple.DwellControl (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imklaunchagent): This service is defined to be constantly running and is inherently inefficient.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.432.4294967295): com.apple.noticeboard.agent (lint): EnablePressuredExit is not compatible with KeepAlive=true. Ignoring EnablePressuredExit.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.432.4294967295): com.apple.pluginkit.pkd (lint): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.432.4294967295): com.apple.tiswitcher (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.432.4294967295): com.apple.universalaccesscontrol (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.432.4294967295): com.apple.universalaccessd (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.UserEventAgent-LoginWindow): This service is defined to be constantly running and is inherently inefficient.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.432.4294967295): com.apple.VoiceOver (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service tried to register a port for an endpoint declared in its launchd.plist(5): service = com.apple.ManagedClient, endpoint = com.apple.mcxd
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc/Contents/MacOS/XPCTimeStampingService error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc/Contents/MacOS/XPCKeychainSandboxCheck error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc/Contents/MacOS/IOServiceAuthorizeAgent error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc/Contents/MacOS/com.apple.SpeechRecognitionCore.brokerd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Failed to bootstrap path: path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc, error = 1: Operation not permitted
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc, error = 1: Operation not permitted
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Failed to bootstrap path: path = /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc, error = 1: Operation not permitted
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Failed to bootstrap path: path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc, error = 1: Operation not permitted
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Failed to bootstrap path: path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc, error = 1: Operation not permitted
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Failed to bootstrap path: path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc, error = 1: Operation not permitted
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/XPCServices/com.apple.FCiCloudPrefUpdater.xpc/Contents/MacOS/com.apple.FCiCloudPrefUpdater error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:21 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:23 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:23 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/XPCServices/com.apple.tonelibraryd.xpc/Contents/MacOS/com.apple.tonelibraryd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:23 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:23 Seths-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 25 11:18:23 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:23 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/AccountsDaemon.framework/XPCServices/DataclassOwnersManager.xpc/Contents/MacOS/DataclassOwnersManager error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:23 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:23 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.442): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 25 11:18:23 Seths-iMac awdd[194]: Diagnostics Report
Feb 25 11:18:25 Seths-iMac com.apple.xpc.launchd[1] (com.apple.diskspaced[414]): Service did not exit 5 seconds after SIGTERM. Sending SIGKILL.
Feb 25 11:18:25 Seths-iMac com.apple.xpc.launchd[1] (com.apple.protectedcloudstorage.protectedcloudkeysyncing[374]): Service did not exit 5 seconds after SIGTERM. Sending SIGKILL.
Feb 25 11:18:25 Seths-iMac com.apple.xpc.launchd[1] (com.apple.fileprovider.fileproviderd[253]): Service did not exit 5 seconds after SIGTERM. Sending SIGKILL.
Feb 25 11:18:25 Seths-iMac systemstats[66]: assertion failed: 17G66: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
Feb 25 11:18:33 --- last message repeated 3 times ---
Feb 25 11:18:33 Seths-iMac com.apple.xpc.launchd[1] (com.apple.dpd[182]): Service exited with abnormal code: 75
Feb 25 11:18:42 Seths-iMac sessionlogoutd[450]: DEAD_PROCESS: 432 console
Feb 25 11:18:42 Seths-iMac shutdown[451]: SHUTDOWN_TIME: 1582651122 840704
Feb 25 11:18:42 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): System shutdown initiated by: shutdown.451<-sessionlogoutd.450<-launchd.1
Feb 25 11:18:57 localhost bootlog[0]: BOOT_TIME 1582651137 0
Feb 25 11:19:17 localhost syslogd[40]: Configuration Notice:
ASL Module "com.apple.authd" sharing output destination "/var/log/asl" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
ASL Module "com.apple.authd" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.callhistory.asl.conf" claims selected messages.
ASL Module "com.apple.cdscheduler" claims selected messages.
ASL Module "com.apple.clouddocs" claims selected messages.
ASL Module "com.apple.contacts.ContactsAutocomplete" claims selected messages.
ASL Module "com.apple.contacts.ContactsUICore" claims selected messages.
ASL Module "com.apple.coreaudio" claims selected messages.
ASL Module "com.apple.CoreDuetAdmissionControl" claims selected messages.
ASL Module "com.apple.eventmonitor" claims selected messages.
ASL Module "com.apple.family.asl" claims selected messages.
ASL Module "com.apple.icloud.fmfd" claims selected messages.
Feb 25 11:19:18 --- last message repeated 2 times ---
ASL Module "com.apple.install" claims selected messages.
ASL Module "com.apple.iokit.power" claims selected messages.
ASL Module "com.apple.mail" claims selected messages.
ASL Module "com.apple.MessageTracer" claims selected messages.
ASL Module "com.apple.mkb" claims selected messages.
ASL Module "com.apple.mkb.internal" sharing output destination "/private/var/log/keybagd.log" with ASL Module "com.apple.mkb".
Output parameters from ASL Module "com.apple.mkb" override any specified in ASL Module "com.apple.mkb.internal".
ASL Module "com.apple.networking.networkextension" sharing output destination "/Library/Logs/CrashReporter" with ASL Module "com.apple.networking.boringssl".
Output parameters from ASL Module "com.apple.networking.boringssl" override any specified in ASL Module "com.apple.networking.networkextension".
ASL Module "com.apple.performance" claims selected messages.
ASL Module "com.apple.secinitd" claims selected messages.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1]: Early boot complete. Continuing system boot.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.AirPlayXPCHelper): This service is defined to be constantly running and is inherently inefficient.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): com.apple.alf (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.auditd): The TimeOut key is no longer respected. It never did anything anyway.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.autofsd): This service is defined to be constantly running and is inherently inefficient.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): com.apple.backupd-helper (lint): EnablePressuredExit is not compatible with KeepAlive=true. Ignoring EnablePressuredExit.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): com.apple.backupd-helper (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.backupd-helper): This service is defined to be constantly running and is inherently inefficient.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): com.apple.backupd (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 25 11:19:18 --- last message repeated 1 time ---
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.cmio.AVCAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.cmio.IIDCVideoAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Feb 25 11:19:07 localhost com.apple.xpc.launchd[1] (com.apple.cmio.VDCAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Feb 25 11:19:17 localhost syslogd[40]: ASL Sender Statistics
Feb 25 11:19:17 localhost com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.ManagedClient.startup" tried to register for endpoint "com.apple.ManagedClient.agent" already registered by owner: com.apple.ManagedClient
Feb 25 11:19:17 localhost Installer Progress[65]: Progress UI App Starting
Feb 25 11:19:18 localhost cfprefsd[100]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:19:20 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.202): com.apple.pluginkit.pkd (lint): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 25 11:19:20 Seths-iMac xpcproxy[140]: libcoreservices: _dirhelper_userdir: 529: bootstrap_look_up returned (ipc/send) invalid destination port
Feb 25 11:19:21 Seths-iMac launchd[1]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:19:23 Seths-iMac xpcproxy[164]: libcoreservices: _dirhelper_userdir: 529: bootstrap_look_up returned (ipc/send) invalid destination port
Feb 25 11:19:28 Seths-iMac xpcproxy[173]: libcoreservices: _dirhelper_userdir: 529: bootstrap_look_up returned (ipc/send) invalid destination port
Feb 25 11:19:29 Seths-iMac xpcproxy[174]: libcoreservices: _dirhelper_userdir: 529: bootstrap_look_up returned (ipc/send) invalid destination port
Feb 25 11:19:31 Seths-iMac systemstats[50]: assertion failed: 17G66: systemstats + 187906 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x0
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSPerAppTokenMap is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806eb8) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f76790). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSPerAppTokenMapEntry is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806ee0) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f767b8). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSCertificateStorage is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806d78) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f769c0). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSPreferences is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806f08) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f76ce0). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSSystemUser is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806f30) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f76e70). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSMultiUserMode is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806e68) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f773c0). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSIncomingMessage is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806dc8) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f774d8). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSLog is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806df0) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f77528). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSMessage is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806e18) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f775a0). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSMultiUserFS is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806e40) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f775f0). One of the two will be used. Which one is undefined.
Feb 25 11:19:34 Seths-iMac apsd[177]: objc[177]: Class APSOutgoingMessage is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806e90) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x100f77668). One of the two will be used. Which one is undefined.
Feb 25 11:19:35 Seths-iMac xpcproxy[180]: libcoreservices: _dirhelper_userdir: 529: bootstrap_look_up returned (ipc/send) invalid destination port
Feb 25 11:19:48 Seths-iMac airportd[175]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:19:48 Seths-iMac findmydeviced[188]: objc[188]: Class LocalizedUnregisterErrorKey is implemented in both /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice (0x7fffa6aa70a8) and /usr/libexec/findmydeviced (0x1053ce668). One of the two will be used. Which one is undefined.
Feb 25 11:19:48 Seths-iMac mds[61]: objc[61]: Class MDSObjectToken is implemented in both /System/Library/PrivateFrameworks/SpotlightServerKit.framework/Versions/A/SpotlightServerKit (0x7fffa8f7b560) and /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds (0x101883e68). One of the two will be used. Which one is undefined.
Feb 25 11:19:48 Seths-iMac mds[61]: objc[61]: Class MDSToken is implemented in both /System/Library/PrivateFrameworks/SpotlightServerKit.framework/Versions/A/SpotlightServerKit (0x7fffa8f7b510) and /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds (0x1018843b8). One of the two will be used. Which one is undefined.
Feb 25 11:19:48 Seths-iMac mds[61]: objc[61]: Class MDSReadCopyUpdate is implemented in both /System/Library/PrivateFrameworks/SpotlightServerKit.framework/Versions/A/SpotlightServerKit (0x7fffa8f7b5b0) and /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds (0x101884f48). One of the two will be used. Which one is undefined.
Feb 25 11:19:48 Seths-iMac mds[61]: objc[61]: Class MDSInternalToken is implemented in both /System/Library/PrivateFrameworks/SpotlightServerKit.framework/Versions/A/SpotlightServerKit (0x7fffa8f7b4c0) and /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds (0x101886028). One of the two will be used. Which one is undefined.
Feb 25 11:19:48 Seths-iMac xpcproxy[189]: libcoreservices: _dirhelper_userdir: 529: bootstrap_look_up returned (ipc/send) invalid destination port
Feb 25 11:19:48 Seths-iMac nsurlsessiond[146]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
Feb 25 11:19:49 Seths-iMac timed[76]: settimeofday({0x5e555735,0x4c205}) == 0
Feb 25 11:19:50 Seths-iMac netbiosd[189]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSPerAppTokenMap is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806eb8) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c302790). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSPerAppTokenMapEntry is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806ee0) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c3027b8). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSCertificateStorage is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806d78) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c3029c0). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSPreferences is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806f08) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c302ce0). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSSystemUser is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806f30) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c302e70). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSMultiUserMode is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806e68) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c3033c0). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSIncomingMessage is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806dc8) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c3034d8). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSLog is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806df0) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c303528). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSMessage is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806e18) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c3035a0). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSMultiUserFS is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806e40) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c3035f0). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac apsd[193]: objc[193]: Class APSOutgoingMessage is implemented in both /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService (0x7fffa5806e90) and /System/Library/PrivateFrameworks/ApplePushService.framework/apsd (0x10c303668). One of the two will be used. Which one is undefined.
Feb 25 11:19:51 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.89): com.apple.pluginkit.pkd (lint): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 25 11:20:32 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.205): com.apple.pluginkit.pkd (lint): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 25 11:21:02 Seths-iMac com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.501): com.apple.pluginkit.pkd (lint): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 25 11:21:04 Seths-iMac cfprefsd[211]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Feb 25 11:23:20 Seths-iMac systemstats[50]: assertion failed: 17G66: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
Feb 25 11:29:38 Seths-iMac syslogd[40]: ASL Sender Statistics
1 Comment
Could it be a virus?
by
Add a comment
1 Answer
Most Helpful Answer
Sounds like your Radeon HD 4670 graphics board driver is corrupted.
Are you able to setup on a separate Mac system a bootable external drive with High Sierra which your system can boot up from?
Score 1
22 Comments:
I am trying that now!
by
I added the system.log
by
Also, this is a fresh install of High Sierra
by
@sethblackwater - Did you press the Option key so you can select the external drive?
Reference: Mac startup key combinations
by
This was the hard drive trying to boot. I don't have a bootable USB with High Sierra on it. I am making one now.
by
Show 17 more comments
Add a comment
Add your answer
SethB will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 802
