Have a Bios Error on a 5100 Acer
Laptop will go into Bios but before I go into CMOS program I get an error saying conflicting IO on PCI slot 3. Problem is I'm not finding any settings to modify operating PCI slots. As well this computer was said to have a virus so it will not allow me to look at the OS installed.
Specs:
Acer Aspire BL51
Turion x2 MK-36 2.0 Ghz
1GB Pc4200 200 pin Sodimm
Wireless Adapter: Atheros AR5BMB
160 GB HDD
OS: Windows Vista Home Premium
Any ideas as to what may be wrong been searching and have found no manuals to tear this thing apart and check for loose connections etc.
2 Comments
How are the system resources set in the BIOS? Is it set to auto or user defined? Also is plug and play OS set to yes in the BIOS? I believe that the Acer uses the PCI slot 3 for the SD card reader. If your model is equipment with that, try to change your system settings accordingly. Also, do you get the hit F1 to continue or anything like that after you receive your interrupt error message?
by oldturkey03
It asks me to hit F1 to continue and this model does have a SD Card reader. Error Screen Reads:
System BIOS Version: V2.70
Bus:06, Device:02, Function,00
ERROR
Resource Conflict - PCI in slot 03
Bus:06, Device:04, Function:00
ERROR
Bus:06, Device:04, Function:01
ERROR
Bus:06, Device:04, Function:02
ERROR
Bus:06, Device:04, Function:03
ERROR
Press <F1> to resume, <F2> to Setup
That is all I'm getting I may have to see if I can disable or remove the SD Card reader its unnecessary for me to have anyways.
by Mike Maurer
