Repairs for most tablet computers. Because of their small size and frequent use of adhesive, tablet repair is often more involved than laptop repair.
18916 Questions View all
Why wont it turn on?
i bought an archos 101 without a charger and bought one direct from archos via internet. its been charging over night and still wont start and green light still shows solid... is there anything that can be done to get it turned on?
1 Comment:
did you buy it used or new. do you still have warranty on it? If it was used, what did the previous owner tell you about the device?
by
Add a comment
There may be a problem with your charger. Even thought the light is on, it may not be going through the wire into your device. I would try a new charger, or else, check the end of the charger with a powerful multimeter (warning: very high voltages when dealing with this) and if it shows a voltage, the charger should be fine. If you get to this part, you will have to repair your charger port.
If if still isn't working, it may be your battery in your device and/or the board of the device. (may have got fried during charging)
Add a comment
I am having the same problem, but I can only charge mine with the usb cable. How do I go about repairing the charger port?
1 Comment:
Darius,don't you charge it charge it by connecting it to the USB port of your computer or the charger. So, if it charges trough the same port but different devices, i.e your computer or the charger, then it is not the port that is malfunctioning, but the charging device. In your case the charger itself.
by
Add a comment
I have had 4 Archos tablets and none of them worked. What's up with that co. I got a laptop now gateway and I love it never have problems with it. I think somebody needs to go out of business or your going to be sued!!!
Add a comment
Add your answer
gary will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 3,138
