iPod Classic 7th - Center Button click but does not work
French message will follow.
Hi everyone,
I have an ipod Classic 7th (or 6+). Since I recently decided to use it again, I noticed the center button felt odd. But there was nothing to worry about at first. Recently, I change the battery, the Hard Drive for a memory card and the grey faceplate. Everything worked fine for a while but the center button still felt “wrong”. Sometimes it worked on the first try, sometimes I had to push a little bit harder.
Finally, one day, the center button gave up. The others button are fine. I believe they are fine but I can’t test it anymore. I can still scroll in the menus. I have restored the ipod twice. I have finally opened the Ipod again to take a look. I did not see anything strange or irregular inside. I tried to press the center button directly on the pcb but it still does not work. I can clearly hear the click with or without the “plastic cover button”.
At this point, I am starting to think something wrong with the motherboard. But I am kinda a novice and can be wrong. So maybe you guys will be able to help me before I buy a new one. :)
PS: I bought this ipod on ebay. I do not believe someone opened it before me. But the first time I opened it, I found an extra loose screw star head. Any idea where it can come from ?
Thanks in advance for your time.
Update (09 November 2021)
Allo,
Thanks for your help. Last time I used a multimeter was in high school more than a decade ago. Be gentle ahah
Here what I found:
The ipod: https://ibb.co/sHLwsg5
How I measured: https://ibb.co/mHFZnBC
Measure before the button pressed: https://ibb.co/CVx7KZj
During I pressed the button, the measure the value was 0 or very close
Measure after the button pressed: https://ibb.co/jVc5ZXw
Tried to did my best not to move. I am not sure where the "measure after the button pressed" comes from. For some reason, the center button was working a little bit today. But not the play button anymore....
What do you think ?
Thanks again :)
PS : sorry for the delay and thank you for your help :)
