The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
371 Questions View all
The console is not powering on
Hi!
I purchased a used 3DS XL 2015 recently. I knew that it was not functioning. My plan is to repair it and have fun with it. The symptoms are the following:
  • When the device is turned on, the blue led lights up as a normal operation.
  • Neither of the displays turning on.
  • About 5-10 seconds later the bottom screen faintly flashes once, then the LED is turning off.
  • No popping sound from the speakers.
The troubleshooting that I did:
  • I checked the battery it holds the charge well. Currently it is at maximum capacity, ~4.1V.
  • I checked the fuses on the board, they’re not shorted.
  • I reconnected all ribbon cables.
  • I checked for water damage, by checking the water damage indicator stickers on the main boards.
Do you have any ideas what might be the issue? The repair guides that I could find in the internet are useless for this issue. I know iFixit has a good community.
Best regards,
István
Score 1
Add a comment
1 Answer
Hi @istvan_kreisch ,
Please check the daughterboard that has the battery terminal on it. I had to replace at least two of them.
If you have a second working console, you can try swapping the daughterboard and see if that resolves the issue.
1 Comment:
Hello Adam!
Thanks for the reply. Sadly I have no other consoles, just a simple 3DS XL, but as far as I know that is not compatible with the new.
Shall I re-flow the controller chip? I have the necessary equipment.
To be safe, I think I will order a new daughter board. I will get a feedback to you when I replaced the daughter board.
Best regards,
István
by
Add a comment
Add your answer
István Kreisch will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 102
