Repair information for tools used for specific tasks like fixing, building, or cutting. Learn how to use tools that work to fix the ones that don't.
making/replacing case for bits and tools
So i recently purchased a manta bit set and was wondering if anyone had taken the labelled foam insert from one of the bit sets and made or fit it into another form of case. I do like the case that it comes in, but i’m a tradesman and need something a little more secure/waterproof for example clips and a rubber seal. Thank you to anyone who can help me out!
Score 2
Add a comment
1 Answer
This case would fit almost perfectly, and is watertight and sufficiently robust
https://www.amazon.com/Plano-Guide-3600-...
The case the driver set comes in is 216 x 175 x 35 mm, and this Plano one is 280 x 178 x 101 mm
It is slightly oversized for the kit, but you could easily remedy that by placing or gluing in pieces of foam to fill the gaps.
Add a comment
Add your answer
Leo Amies will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 11
All Time: 238
