Guides and support for various television (TV) brands and styles.
9058 Questions View all
Sharp Aquos LC-60UQ17U Bright Yellow narrow vertical line
Hey, I have a Sharp Aquos LC-60UQ17U Bright Yellow narrow vertical line running top to bottom on the screen. About 1/3 in from the right side. All inputs. About 6 years old. Just started. Thanks
Update (01/27/2020)
This is what the screen show on start up.
Add a comment
1 Answer
Most Helpful Answer
Hi
It could be a panel tab connection problem or a TCON board /TCON board connection problem.
The TCON board connects to tab connectors along the top of the panel which are directly connected to the panel itself.
Try gently (stress gently) pressing down on the tab connector located near or above the line and check if this resolves the problem. If not check the TCON cable connections as well.
If nothing works it may still be a TCON board problem or a panel problem. If it is a panel problem then the panel will have to be replaced, if you can find a replacement that is that is not nearly as expensive as a new TV
Score 1
2 Comments:
I will give it a try. Might have to wait till I have some help to get to the back of it for removal. Thank you.
by
Hi Bob, were you able to fix the problem? I have the exact same issue.
by
Add a comment
Add your answer
Bob Severtski will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 19
All Time: 1,037
