Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2265 Questions View all
Replaced my screen, sound not working or vibrate, headphones work tho
I replaced my screen (at my own risk) but as i was reassembling the bottom right corner wouldn’t go down without pressure, now vibrate and sound dont work out the speakers also the home button, sound works through headphones and bluetooth speakers (except alarms) just no message alerts through sound whatsoever, i’ve researched all the methods and no luck, any help?
Add a comment
1 Answer
Chosen Solution
Your description is a little confusing but this sounds like an Audio IC issue.
This can happen seemingly out of nowhere and usually follows a reboot of an affected device, like when you shut it down to repair it. Sometimes the removal of the screen gives the logic board that last “flex” that puts it over the edge. Once rebooted, the phone exhibits symptoms that were never present before.
The iPhone 7 series of devices have proven to be very unreliable, suffering from flex-based issues similar to the iPhone 6 Plus (Touch Disease). On the iPhone 7, the fault line runs along the top of the SIM card reader and affects the Baseband CPU and Audio IC. Any short copper traces running perpendicular to the fault line while connecting to micro-BGA pads, is subject to failing.
On the Audio IC, this particularly affects the C12 pad/trace although there are 4 pads/traces along the fault line. Of those four, the C12 pad (I2S_AP_TO_CODEC_MCLK) is the most critical as it is a communication protocol line between the CPU and the Audio IC.
Here are the typical symptoms, as collated by the repair community:
  1. Voice Memos app / Loudspeaker on call - greyed out
  2. Siri doesn’t hear you / Caller can’t hear you
  3. Most other Audio related issues that aren’t solved by modular replacements
  4. Long boot times (3-5 minutes)
  5. iTunes detects the phone but stuck on the Apple Logo
This is a repairable problem but it requires a micro-soldering repair. Although it can be a routine repair for an experienced tech, it can go sideways very quickly as the Audio IC is directly opposite the underfilled Baseband CPU.
Score 1
2 Comments:
Thanks you that was very descriptive, the earpiece still works and i can make phone calls, its just the base speakers and the home button, i’ve rebooted and itunes looped the phone into recovery mode so i exited and now im just stuck, i was hoping it’d be an easy fix
by
Unfortunately, no. There are some temporary fixes, like applying pressure to the logic board but those just make the root cause worse long-term. If you want a permanent solution, then a microsoldering repair is the way to go.
by
Add a comment
Add your answer
joshnicol will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 51
