2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
will this upper case fix my problem?
So my friend spilt liquid on her macbook,
it's a white macbook unibody, MC516LL/A ,
Intel® Core 2 Duo Processor 2.4GHz
2GB DDR3-1066 SDRAM
250GB 5,400RPM Hard Drive
13.3" Widescreen Display)
Now half of the keyboard doesn't work anymore (left side and delete key on the other side). wonder if the item you are selling ll fix it if i buy and replace it.
Also is that the right upper case for her macbook?
Thank you
1 Comment
so After i swap everything to the new upper case, it won't turn on. i thought maybe the new upper case isn't working so i put everything back to the old upper case but still doesn't wants to turn on. what should i do next?
by
Add a comment
Chosen Solution
You need the Apple Part # 661-5590
MacBook Unibody (A1342) Upper Case
MacBook Unibody (A1342) Upper Case Image
Product
$179.99
Score 3
Add a comment
You should put the logicboard in Isopropyl alcohol first, there might be corrosion somewhere
If that doesn't help, you can try, but i will not guarantee anything
If the topcase doesn't work, return it and buy a logicboard
Add a comment
Add your answer
micheltichu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 813
