Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
Replaced the microphone but now phone isn't charging.
My microphone stopped working a few days ago and so I bought a new microphone/charging port and then installed it using the help of a youtube guide. My microphone now works fine however my phone will no longer charge. Any help?
Add a comment
1 Answer
Most Helpful Answer
A Few things can cause this issue,
  1. You received a bad charging port with a good Mic
2. The Charging Flex is not making a good connection to the board
3. You caused pry damage, knocking off or dislodging one of the small components in the surrounding area
But first, unplug battery, remove screen assembly (So you dont damage flex cables)… and measure the board for 5v dc at the test point to see if you are receiving voltage from the port when plugged in.
You can also measure the charging voltage at battery terminal if you are getting 5v to see if charging circuit is operating normally.
Post back results after these first 2 things and also look carefully for pry damage
Score 2
Add a comment
Add your answer
Luke Stuckey d will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 51
