A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
971 Questions View all
Toshiba Satellite L515 Laptop Keyboard, how can I repair some keys?
hi! since 3 months, i have some troubles with my keyboard, some keys doesnt work (e,d,c,r,f,v, ñ, p, 3,4,0)
If you now the way to fix my keybord please let me now. hoping have greats days, good bye.
laptop: toshiba satellite-l515
Add a comment
Chosen Solution
This is what the service manual for your computer suggest.
Check 1 Make sure the keyboard cable has been firmly connected to the system board. Keyboard System board CPU If the cable is loose or off, reconnect it firmly and return to Procedure 1.
If there is still an error, perform Check 2.
Check 2 The keyboard may be faulty. Replace it with a new one following the instructions in Chapter 4. If the problem persists, perform Check 3.
Check 3 The System board may be faulty. Replace it with a new one following the instructions in Chapter 4. If the keyboard is still not functioning properly, perform Check 4.
Check 4 The memory may be defective. Replace the memory module with a new one following the steps described in Chapter 4. If the problem persist, perform Check 5.
Check 5 The CPU may be faulty. Disassemble the computer following the steps described in Chapter 4 and replace the CPU with a new one.
So now where all those steps are listed, here are the instructions for the keyboard removal and the service manual is available right here. Good Luck
Score 2
Add a comment
There's a ribbon underneath that can easily get slightly loose. Toshiba has local service centers with live people in many areas and this would be like a 30 second no-cost fix.
If you can remove the keyboard (not all the way!) look underneath at the ribbon and simply press lightly downward (straight!) on the ribbon and the clip retaining the ribbon on the motherboard. Be careful that all screws are tight, but be more careful to not overtighten screws going into plastic!
Add a comment
Add your answer
matias will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,194
