Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
iPhone 7 Freezing/Boot Looping
Woke up at 5am today to my phone stuck on the apple logo. Tried updating through iTunes to no avail and had to restore. Restore was successful and I restored a back up, while downloading spotify it froze and turned off. It bootlooped slowly around 7 times and now it's just solidly on the apple logo. Phone also gets warm to the touch. Battery is 100% not the issue. Phone is also fully charged. Any suggestions help, thanks.
Add a comment
1 Answer
Chosen Solution
Did anything happen to the device in the days and weeks leading up to this issue, such as a drop, a repair attempt or contact with water?
Assuming this was a spontaneous failure, it is probably a failed component on the logic board. The iPhone 7 is prone to several issues after repeated minor drops and flexing over the course of its life. It could also be a dead or dying battery or modular component.
If you have access to a multimeter, you could measure the battery first. If it reads ~3.8V - 4.2V, then it is good.
I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex. Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the Home button flex first, then add the rear camera, LCD & Digitizer then from camera flex.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair. Sometimes the fix can be straightforward (i.e.  a blown filter) and relatively economical.
Score 1
1 Comment:
I've tried restoring through iTunes multiple times with different cables, computers etc and I get error 9. The phone has never been opened or repaired (yes I do repair iPhones too) and I've owned it since about mid 2018. After a week of buying it new I dropped it and it gained a small crack but that was the only time it was ever dropped and that's almost 2 years ago. It's also never had any water damage, battery health was pretty high with low cycles and everything was working fine before this, no errors, crashes, speed decrease etc.
by
Add a comment
Add your answer
Jakob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 127
