Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Do I need the battery bracket and front panel bracket?
I have an iPhone 6 which is missing both brackets from the front panel and the battery. The cost of buying these, the battery bracket, the front panel bracket, and a new screw set to screw these brackets in, is almost $30. I also have to replace the battery which will cost me another $25. Is there a need for covering the cables so I can maybe save some money as I only have $50 to spend?
Add a comment
Chosen Solution
It is better if you have bracket, that prevents undo the connections from motherboard when phone drops accidently. Without bracket phone will function, but wouldn't recommend it.
Score 1
1 Comment:
Thanks for the feedback Raj! I will be sure to install the brackets.
by
Add a comment
You can buy them from a chinese website for less then 5 bucks,
Score 1
1 Comment:
Thank you for the tip!
by
Add a comment
Add your answer
Alex Zhang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 159
