Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Backlight upper left corner
Hi,
I recently replaced my screen (backlight, touch, etc)and after few days the upper left corner of backlight stopped working. I powered phone off then on and then backlight worked perfectly for an hour. It happens every time I power off then on my IPhone. Could it be that I didn’t connect properly the flex cable ?
IPhone 6s Plus
Thanks in advance!
Update (01/05/2020)
Thank very much for reply.
I checked if it is not properly connected and it looked connected properly. But, when I turn phone on the flex cable for backlight gets really hot while screen is on. As I suspected, there is a short circuit at very connection and phone cuts current through hot parts. I will order another screen with backlight and test if it is on flex cable or board.
Add a comment
1 Answer
Most Helpful Answer
Non properly connection, Bad Back Light from the Screen or Bad back light from the board, always disconnect your battery when you are fixing you phone. Good Luck!
Score 1
Add a comment
Add your answer
mare96po will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 73
