Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Why won't my iPhone turn on?
The iPhone (8gb, 3G, not jailbroken, unlocked) won't turn on, i haven't dropped it or anything, when i try to turn it on it just appears the apple logo for about 30 seconds or so and then it turns off again.
when I plug it to the USB connector or charger it happens the same, the silver logo for 30 seconds and turns off.
I've tried restarting it several times but it does the same everytime.
Score 1
Add a comment
Most Helpful Answer
Sounds unfortunately like a bad logic board, which kinda means you're screwed, no point in replacing that.
You may want to try both resetting and restoring it (if you possibly can) just in case that does something.
Score 1
Add a comment
Yeah give restoring it a try, if not see if you can still claim a repair/replacement under warranty.
Add a comment
Add your answer
Andrea will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,948
