Vertical lines on screen
Hi. Does anyone have any idea what these lines on my screen may be caused from? They will come and go but lately have been constant. I have changed the other devices connected to the tv. So it does not appear to be and HDMI issue. Thanks
Add a comment
Chosen Solution
Hi,
The lines could be caused by either a faulty TCON board or an intermittent Tab connection onto the screen itself.
There are connectors which connect from the TCON board onto the screen. They are very fragile and sometimes come loose. You could try gently pressing the tab to see if the line disappears.
How old is the TV?
If it is under 12 months it should still be covered by the manufacturer’s warranty.
If it is go the warranty route first. Curved displays are very easy to damage if you’re not careful
Score 1
Add a comment
I had the same problem. Got a dif one connect box and its gone
Add a comment
Add your answer
Walt Kerley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,597
