The Asus K53E-BBR3 is a stylish 15.6 inch metallic notebook for everyday use that came out in 2011.
6 Questions View all
DC power jack loose
Can anyone helpme, this just occured today. When i was charging my laptop it suddenly not charging so i push and it work only if i pushed it. After searching on the internet it says that my laptop dc jack has come loose, can anyone help what should i do with this.
Add a comment
1 Answer
Most Helpful Answer
If the power jack has come loose, you need a soldering iron to reattach it to the motherboard. It needs to be a good one, the cheap ones don’t get a good enough temperature to get rid of the old solder. If the power jack itself is damaged, you can usually buy a replacement power jack online with the correct make and model number of the laptop.
If you’re not that good with a soldering iron, or don’t have one, then you can disassemble the laptop and take the motherboard and power jack to a computer repair shop and they should be able to do it. Most of the time is taken up by the disassembly as it can be a bit persnickety, but instructions are available online and on YouYube for many different models.
Score 1
Add a comment
Add your answer
Bodybody will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 564
