2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Audio connector red light problem.
Hello. I have a problem with audio output of my Mac. After start the system i saw a red light in audio output connector. Doesnt matter, which system i start Mac or Windows. System show that digital output is enable, no avaliable analog output(repro). When i plug in headphones, analog output start working, digital output is disable. Can it be mechanical damage of the connector? Days before i pluged into Mac cable, which have 3.5 Jack connector little longer then normal.
Add a comment
1 Answer
Chosen Solution
#1 The red light in the headphone jack means that the MacBook Pro thinks that an optical audio cable is plugged into the port. Try unplugging and replugging a headphone plug into the port several times. There is a tiny sensor inside the port that determines whether the port operates in optical or analog mode. Plugging something analog in is supposed to trigger the sensor and restore the analog signal.
#2 Your digital audio out has switched on. You can insert a plastic toothpick in the hole and try and switch it off. The switch should be at the 3 o'clock position and go towards the 6 o'clock position. Some people also have had luck inserting their headphone jack and pulling out a few times. Another recent report was that inserting the headphone jack and turning it in the hole helped.
Score 1
3 Comments:
Thank you for reply! I tried plug jack several time it doesnt help. I will try #2. Thank you for explanation of the connector construction. It must help.
by
Its working! Thank you very much!
by
Glad I could help
by
Add a comment
Add your answer
Max Mizov will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 3,694
