Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 Questions View all
I want to keep volume down
My dad’s hearing isn’t great so puts the volume up to 100. I just can’t take it anymore, it’s just too loud. Is there a way to set the tv where it will only go so loud? Thanks, Losing my mind even going into bedroom and closing door and turning our tv on, all I can hear is his tv. I have asked him to lower but he won’t. I’m 50 and dad’s 80.
Add a comment
1 Answer
Most Helpful Answer
Hi @melissajjjay ,
The TV doesn't provide many audio options and no audio out options at all and reducing the sound level would require modification to the circuit board and the reduced volume would no doubt not be favoured by your father if it is his TV.
Does the TV signal come from an antenna or a box of some description e.g. cable TV box or streaming service device?
If a "box" then I was wondering if it either has an earphone connection or perhaps a Bluetooth option for the audio so that you can connect BT headphones. Getting your father to wear them might be the problem.
If the TV signal comes via an OTA (over the air) antenna you're out of luck unless you buy a new TV that has an audio out or BT function that you can connect headphones to.
If you can get the option to connect headphones somehow, BT or wired, if your father seems unwilling to wear them, suggest that he might appreciate having the sound closer and that he won’t have to struggle to listen as it is direct into the ears with no outside noise getting in the way (if you get the better noise cancelling headphones that is).
Also with BT headphones he can walk around without the danger of tripping over on cable if he wore wired headphones. He could even leave the room and not miss out on what was being said on the TV ;-)
Score 1
Add a comment
Add your answer
Diane will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 73
