A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Questions View all
No battery detection with new Logic Board
Hi I have a A1708 with function keys. After dead logic board I ordered a used one of eBay. Replaced and booting up. First completely erased disc and made full install of delivered high Sierra. Then I saw that no battery is detected (PPT001 in diagnose). Boots up and schows 100% and X in battery symbol. At a short moment it showed battery 0%. Made SMC reset…nothing. High chance of high discharged status of the battery but my usb c tool only shows 0,5A when running…so it’s definetely not charging.
what is the problem with “new” logic board and old battery ? Is there any workaround? Thx on advance
Update (12/14/2019)
Looks like there is something wrong with dates?
Had the Problem with date at new installation of High Sierra with “CERT” failure because date was set to 19xx.
Score 1
9 Comments
Run CoconutBattery and post a snapshot here for us to see Adding images to an existing question
by
Does coconut Display different results than System report? System report says no battery detected
by
It offers a better view and boils it all down into a more compact screen. Please let's see what it shows us.
For reference: Battery suddenly not recognized. MBP Fn 2017 which has a similar problem.
by
Posted it down below. Strange thing is, when I start up and the apple logo and statusbar is on screen and I pull the cord, then it loads till system is "up"...then it shuts off.
by
@BenjaminS - This makes sense! When you disconnect the USB-C power cable the system looses its settings so the date reverts to the default 1979.
by
Show 4 more comments
Add a comment
Chosen Solution
Thank you dan for your advice.
SOLVED:
It was the “Data-Cable” which connects Battery and Main Logic-Board. Just replaced it with a new one and its working again.
Score 1
Add a comment
You need to replace the battery as the micro controller within it is not working so its not charging properly. Here’s the needed part MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery you’ll need to reference this guide MacBook Pro 13" Function Keys Late 2016 Battery Replacement
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery Image
Product
$129.99
Score 1
5 Comments:
Are you sure ? Before replacing the Board everything worked fine. Are there any probe points or another way to test the battery? When I measure simple at the two contacts on the Battery board I get 5,8 V ...seems a little to low? Does anyone have voltages to test ?
by
Sorry you've damaged it somehow.
by
Starting in single user mode and pulling cord stays on. Only when exit single user mode shuts off
by
OK, so what does CoconutBattery say in Single User?
by
@BenjaminS - Happy it all worked out! Don't forget to score the answer and accept it so its closed out.
by
Add a comment
Hi, lately I installed an NVME M.2 ssd and after unplugging the battery board data cable I ripped of the head. After installing everything and plugging everything the MacBook don't start anymore with the battery and it doesn't show up on the sidebar. I ordered a new battery board data cable and plugged that won in with no results. Am I missing something ?? any setting ?? or manipulation ?? I did everything step by step. Please help !!
1 Comment:
@agredach - Best to create a fresh question. This series uses a custom SSD it does not offer a M.2 interface for a M.2 SSD.
by
Add a comment
Add your answer
BenjaminS will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 624
