Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Questions View all
Why is phone 8 touch screen not working when home button is plugged in
iphone 8 touch screen not working when home button is plugged in. But when i remover the home buttom cable touch the screen works. the connections look clean.
I replace the screen with an original Apple screen. Even tried the original screen that the iPhone have still have same issue
I don't know if it's on motherboard issue I'm assuming it is
Add a comment
Chosen Solution
This is one of the common problem shown on the iPhone 8 Plus.I also faced that problem and i solved it.That problem is actually from the pin name display to MAMBA MSYNC CONNECTION pin problem.If you still stuck on that problem that is extremely helpful for you.Before doing you need some knowledge about micro soldering.Do that job carefully.
Score 1
Add a comment
Plz help me I am stuck in this formate and how do I solve it
Add a comment
Add your answer
isaac castro will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 8
All Time: 1,207
