Repair guides for Android cell phones manufactured by HTC.
1325 Questions View all
Is a replacement charging port for HTC innovation for Verizon avail..
the little plastic separator inside the charging port broke off and I was wondering if it is worth trying to replacing?
Thank you in advance JH
It depends how involved you want to get and if you have access to the parts. Also, since there is some soldering involved, your skill level will matter. Which HTC is it?
Add a comment
1 Answer
Chosen Solution
It can be done, but take your time!
There are no guides on how, but my only advice is use a very small soldering tip and this will be much easier
I repaired my friend's touch(his dog knocked it off the table and the connector for the cable broke in it with no luck removing it
Go to radio shack and find a sldering iron with a small tip or a seprate tip
follow this guide, I do not have time to write a guide yet, but I will
Add a comment
Add your answer
Jeromy Holding will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,429
