The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
Would I need to replace the LCD or the LCD with digitizer?
I have an s9 and I've dropped my phone which crashed. I tried turning on my phone and it only show the top half and the bottom half green screen flickering. I'm not sure which part of the phone I should get fix and I have little to no knowledge about this.
Add a comment
Samsung Displays are the more high tech on the market, OLED Display ,TouchScreen and Front glass come from factory in sandwich mode less than 2mm, replacing single parts such as OLED or Touch Screen requires expensive equipment, and in your case you have a bad OLED Display (The Expensive Part), so you have to replace the complete Screen sandwich.
SUMMARY: Replace OLED Screen Assembly, is DIY Project, Replace OLED Screen Assmebly with Frame/Housing.
1 Comment:
Yes, thank you and i know its really expensive part. I broke it recently and wasn't sure which part to get it fixed which I asked phone repair shop and they say around $260 and up.
by
Add a comment
The LCD and the digitizer are basically fused together. You will need to replace both. If you are doing it yourself then good luck, the screen is glued on tight.
Add a comment
Add your answer
kelly tran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 718
