Remove PCB from metallic casing?
I’m disassembling an old and malfunctioning LG E2360V-PN monitor to see if I can fix it by replacing the capacitors. But, I was met with an unpleasant surprise: the PCB seems to be enclosed in a metallic casing, and I have no idea how to remove it!
I’ve already unscrewed all visible screws but it won’t budge. The bottom side of the metallic casing has a suspicious notch that seems to be holding it in place, but I’m not that sure what to do about it. I could always try to cut the metallic case, but I fear I’ll probably damage the board like that…
Bottom view with notch in red square:
Top view:
Any ideas/suggestions are welcome!
Add a comment
Chosen Solution
In case anybody from the future finds this page, I managed to solve it! In the end, these little guys where the problem:
By removing them with a socket wrench the PCB finally got free.
Add a comment
Did replacing the caps fix it?
1 Comment:
Actually it didn't! In the end, turns out the problem was the power supply.
by
Add a comment
Add your answer
ALONSO CANALES ECHEVERRIA will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 319
