Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
Why error message come up periodically?
Error messages 5Y (Freezer) and EF (Refrigerator) come up periodically for Kenmore French door refrigerator. I already turned off power and reset twice but error messages are coming up periodically. Any solution to the problem?
4 Comments
Hi @rampur ,
What is the model number of the fridge?
by
Kenmore French Door
Model #253. 70313213
by
Thank you. I did disconnect the power and error messages disappeared. However, error messages came back after a few days and so I unplugged again and the messages disappeared. I have now done it 3 times, it has no error messages at this time.
Based on your suggestion, something is happening, so do you suggest anything further to rectify the problem?
by
always check the fan. Make sure it works properly
by
Add a comment
1 Answer
Chosen Solution
@rampur The SY (instead of 5Y) EF code stands for system error with the evaporator fan. This means that there could be something going on with your evaporator fan. Since you have already tried to reset your fridge I’d suggest you take the back cover off and take a look at the fan etc. Make sure that you do not have any ice build up that prevents the fan from coming on which could generate the same error. If all that checks out your fridge may have an issue with the main board.
Score 2
1 Comment:
Thank you, I will take a look at the fan in the back and see if there is any ice build up.
by
Add a comment
Add your answer
Rampur Viswanath will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 631
