Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
iPhone X Face ID not Functioning Properly
So I recently ran into a problem with my iPhone X. I replaced the screen and the Face ID setup won’t work. I have transferred the Serial Number over from the original screen so true tone is functional. No errors come up, it is able to get into the part where it asks you to align your face with the frame. However, it just asks me to move the iPhone a little higher and then a little lower. It won’t actually detect my face but it knows a face is there because if I move my face out of the frame it says that the face is out of view. I have tried cleaning the IR cam, front facing cam, flood illuminator and the dot projector with 99% isopropyl alcohol.
  • Animoji is fully working
  • Portrait mode from the rear facing cameras work but not front facing
  • Face ID setup won’t complete
Anyone ran into this problem and managed to solve it?
Thanks, Andrew
Add a comment
Most Helpful Answer
Check out the two guides and you might know why
Why Face ID Not Working After Repair
Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher'
iPhone X Image
Guide
Difficulty:
Moderate
iPhone X Image
Guide
Difficulty:
Moderate
Score 1
Add a comment
iPhone XS Max Face ID Not Working Fixed - Dot Projector Repair
Add a comment
Add your answer
Andrew Wilson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 488
