Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
iPhone X Boot loop after water damage
Hello guys. I have had my iPhone X for 2 years now and I have taken over 100 pictures underwater with no problem. Three days ago I dropped my iPhone in the bathtub for no more than 2 seconds and got it out. Feeling safe that the phone is waterproof I left it on the shelf and an hour later I looked at the phone at it was bootlooping and having all kinds of strange artifacts on the screen.
I took the sim tray out and left it next to a fan. On the other day the phone wasn’t turning on at all. I left it in a bag of rice for 2 days(I didn’t think it would help). I took it out 2 days later and the phone was showing that there was no battery and still had artifacts and screen flashes.
I removed the screen and tried to dry the phone with a heat gun. After that the screen was fixed and there were no more screen artifacts, but the phone is now bootlooping.(5 seconds apple logo, 5 seconds black screen) until the battery is empty and then it shows the no battery animation again. Any idea what I need to replace or do in order to get the phone to boot, or is the logic board fried ? Thank you.
Update (11/19/2019)
Hello guys. The phone is almost fixed. I cleaned the taptic engine connector and the phone booted. I have 2 remaining problems:
  1. The taptic engine makes very strange metal noises. Most likely it is damaged ?
  2. When heating the phone I have managed to melt the front camera and the infrared camera. All other sensors are ok and there is no error for face id. I know the front camera can be replaced without problems, but will replacing the infrared camera break Face ID ? I know the flood illuminator and the dot projector cannot be replaced, but what about the infrared camera ? Does it have a chip with logic board data ?
Score 2
2 Comments
How hot was the heat gun, and was the battery still installed when you heated it?
by
@reedcrosby
Very hot and the battery was installed, but I never pointed the heat gun at the battery.
by
Add a comment
Chosen Solution
Open charging flex and power on iPhone and check most have vibrator circuit issues.
Score 1
Add a comment
watch this video . will give u an idea how to fix that. https://youtu.be/BU95TBsJxM8 https://youtu.be/BU95TBsJxM8
Score 1
Add a comment
Hello I have the same problem.
totally you find a solution ??
Add a comment
Add your answer
Nikola Hristov will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 885
