How do I replace broken lower duct hose
There is a hose (clear and reinforced with steel coil wire) that connects the floor nozzle to the bottom of the upright handle or “Tube” as it is called in owner’s manual . This hose is called the “lower duct hose”. It’s purpose is to extract all of the debris, that the “beater bar” (brush) stirs up, and suck it up and into the collection tank. This hose has split and causes my cleaner to continuously drop most debris back onto floor. I have the replacement hose but I need a video or some kind of instructions to assist me with this task.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @mrcleanit ,
Not sure but do you mean a Shark Rocket HV300 series vacuum cleaner?
If so here’s a link to the ifixit Shark Rocket HV301 Hose Replacement guide which may be of some help.
Score 1
1 Comment:
Bad, bad, bad instructions. How did you go from step six to reassembly? After totally demolishing my vacuum after using "some force" I had to trash the whole thing. Thanks.
by
Add a comment
Add your answer
Patrick Morris will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 5,146
